My Book 4TB
I have just bought and installed a My Book 4TB but its not showing in Computer, it’s on Device Manager, I can see it to remove a USB device properly.  In Smartware its showing up but states no writeable partition, my existing My Book is showing in all areas - do I have a conflict and if so how do I fix it?  Oh, when I power off my eisting My book and switch on the new one it assumes the “I” drive.
Make sure you have the drive plugged in on a wall outlet.  A power strip or surge might not provide enough power to spin up your drive.
You may also try this link:
Only one drive is seen when connecting two WD external drives of the same size to a Windows 7 or Windows 8 PC
