My Book 3TB
Hello, when i copy to “MY BOOK HDD” (WDBACW0030HBK-EESN) a large file eg. 500 MB or 1 GB, copying is always stucked at 90-97% for a few seconds (5 second maybe).
Note: HDD is almost empty so it shoudnt be fragmented.
OS: Windows 7 SP1
  1. I installed “WD SES Device Driver” included in HDD
  2. Then i installed update WD Driver 3.2.0.8D - driver updated to 1.022
  3. I Turned off PC, i unplugged HDD cables and Turned ON PC and pluged in cables
But the problem still occurs.:crying_cat_face:
Have you tried copying the same amount of files to a different drive?
To my understanding, when you are copying big amount of files, the system will stop at 90 -95% to confirm that all the files are properlly copied and that it does not have any duplicated files.
