My Book 3 on mac book pro doesn't seem to work
I’ve plugged in my new My Book 3 into my mac book pro. The only things that show up when I open it are 3 folders: extras, locale, user manuals. There is no smartware to install.
How do I install it and where can I download the software (any links?)
Thanks :slight_smile:
Hi there and welcome to the WD community
You can check the download section on the WD support website and download the latest software versions, here is a link to the download section:
http://support.wdc.com/product/download.asp?level1=1&lang=en
You should be able to locate the model of your unit and get the latest software for it.
