My car only recognises USB MTB mode .My Mac only recognises MSCmode…how do I load my own iTunes albums onto the Sansa Clip + so that they play in the car?
I also have a windows PC and have had no problem with windows player but I am finding I Tunes frustrating.can anyone help
Well, that’s how Apple sells dopI players.
I’m not in the Apple world but I Googled itunes MTP and this software came up.
http://www.sync-mac.com/mtp-sync.html
Looks like you can try a free version. I’m not endorsing. There’s probably other software out there too.
On the Clip you’d probably have to go to Settings/System Settings/USB Mode and choose MTP. Otherwise AutoDetect will probably flip it into MSC when you connect to the Mac.
Thanks for your help. I will give it a go
You may want to explore specialized software to transfer files from a Mac, such as Hidden Cleaner (freeware) and KopyMac (also freeware; may no longer be easy to find)–Macs (and Apple) can make it difficult to tranfer files to non-Apple devices, and these software programs can make it a breeze; they come highly recommended.
