MicroSD with vanishing files.
@theodora45 wrote:
I have a clip+ and an 8gb card, about 1yr old, and have a new problem.  I a message on my Mac that says ‘not enough memory’ to download, even after I have ‘deleted’ old song on both the disk and the card from my mac. The card now shows 285mb (1 auto book), and 70mb on  the clipp and still the message- not enough memory for either. Do I have unseen files, that I haven’t erased?
Do note that when using a Mac and deleting files from the player, you must empty your Trash while the player is still connected. Otherwise, only the reference to the files will be deleted; the actual files will remain although you will not be able to see them.
Hi there, what does the limit really stand for?
Is it like songs in the library? any single piece of data in the library?
I was wondering, because I wouldn’t care about library limits since I am using folder navigation. Would the clip+ also limt the “titles” in the folder navigation? Why should it?
Thanks.
