Memory Zone not recognizing usb dual drive (usb c) - iOS
I just bought a sandisk dual drive go usb c drive, and what made me go with sandisk even more was the memory zone app that seemed to be just what i was looking for.
After installing the app and connecting the usb drive, it doesn’t recognize it. I tried rebooting the phone, close all apps and open just memory zone, leave the drive connected for a while, install and reinstall. Nothing. Tried on an android phone, same thing.
The flash drive does show up on a computer and on the files app on iOS, but the app just doenst recognize it.
Did i get a faulty drive?
@john323
(Get Support for Your SSDs and Flash Products | SanDisk)
Try this one.
(Contact Support | SanDisk)
I have checked the articles and help section here but with no luck. It doesn’t work on the ios app and android app
@john323 can you see the USB-C drive in the native Android or iOS Files App?
I did. It shows up on the files app in ios, on windows explorer but strangely not on android file app.
I tried formatting the drive in exFAT and also in FAT32 with a software that allows for bigger flash drives to be formatted in FAT32. Nothing worked with making the flash drive detectable on android and on the sandisk on ios or android.
I ended up formatting it back to exFAT as that seems to be the better option for flash drives over 64gb.
I have been able to transfer files to the flash drive with the files app on iOS, but i wanted the convenience and extra features of the sandisk memory zone app and also to be sure that the drive is not defective.
@john323
The drive is detected on computer and files app, so the drive is good.
If you have tried all the steps in these two kbas
Feel free to open a support case.
Contact SanDisk Technical Support for assistance.
(https://shop.sandisk.com/support/contact-us)
I have the exact same problem - newest iOS, newest phone 16 Pro, all uptodate, mac environment - new replacement iXpand Flash drive.
I can see the drive is connected in the file-browser on the iOS device.
I tried all the things on the link you shared above - but nothing seems to work.
no luck so far…
I restarted, closed all apps, tried over and over again with all possible combinations. It wont budge - still says “no device detected”.
Not sure what it is - also checked app details and settings but nothing seems to indicate that something is wrong.
Any other ideas?
I thought of maybe getting an adapter from usbc to lightning to test if that works.
It sounds frustrating! Sometimes the Memory Zone app can be picky with certain USB-C drives. If it works on a computer, your drive is likely fine—I’d try contacting SanDisk support to see if there’s an app update or compatibility fix.
SANDISK App 3.1.0 for iOS supports SANDISK USB Dual and Type-C Drives.
