memory card sizes support
What is the max memory size tha sanza fuze support ? 16 gb ,32 gb?
32 GB cards will work fine. 32 GB micro SDHC cards aren’t available yet.
Given that the largest existing MicorSD card is 16GB, I’d say 16GB.
However, you can use an external adaptor and use a 32GB full-size SD card if you want. It’s already been done. There’s an article on it over at ABI forums. You can get the adaptor at DealExtreme.
