I just purchased the 2GB Sansa Fuze and I can’t seem to find in any of the doumentation a clear answer to my question on any limitations on the size of the microSD that can be used/added to the 2GB Fuze. ANyone know if there is a limit?
I use an 8GB MicroSDHC card (http://www.amazon.com/Sandisk-MicroSDHC-MobileMate-SDSDQR-8192-E11M-Package/dp/B000WH6H1M) with my Fuze and it supports it just fine.
As far as I know, it supports the full MicroSDHC spec, which means 32GB. Of course it’ll probably be a year or two before we see cards that big. I think 16GB are supposed to be out soon (if it isn’t already).
Correct Corilof, the Fuze is SDHC compliant. Currently 8gb being the max, 16 to come very soon
