I have a 1TB WD My Passport Ultra
From day one I have connected it to a MacBook
I no longer have the MacBook and now need to access my files stored on it from a PC
Every PC I try does not recognize there is data on the drive and sometimes does not even recognize the drive itself
Is there anything I can do or anything I need to change in the properties so that a PC will recognize the drive without compromising or losing my existing data
Thank you
Hi, you will need to find a third party application that allows you to read HFS+ partitions on Windows, this should allow you to see the data and get it out.
