I intend to use the Sansa Fuze in my car using the AUX input on the front of the receiver. I’ve researched that it’s best to use the line-out to AUX instead of the headphone out to aux. What options do I have to do this with the Fuze? The only product I found capable of doing this is the Griffin Powerdock.
All you can do is headphone out to your aux. There is a thread on here about how to mod a regualr cabel for a line out, but I dont know if that will work.
Thanks for the quick replies. Let me make sure i’m getting this rite; the Griffin Powerdock will not provide the line-out to aux? I’m not all that talented with soldering so I doubt i’ll be doing the alternative.
Despite its name, the PowerDock doesn’t provide power! It has a USB connection - if you have any generic USB power car adapter, that should provide power. The homemade adapter (in the other thread) also has the advantage that it can also powered by a USB power adapter.
The eBay adapter might work, but its kind of pricey. An alternative would be a View cable, butyou might need a second cable to convert RCA jacks to whatever you have in the car. With either of these, your Fuze battery will be on battery power.
View cables that connect through the dock connector do NOT work on the Fuze. If they have all the pins they can be modified to work. The Fuze needs a voltage feed on pin7 to enable lineout. The View cables do not provide this connection.
