Can I keep the WD Smartware software installed to use the backup software/capability, and also add another folder to the harddrive, and use that foldewr for specific drag and dropping ?
Thanks,
Steve
Thanks,
Steve
You should be able to.
Thanks. Yep, it seems to be working well.
Thanks again,
Steve
What was the solution to your question? !?!?!?!?!?!?!??!!?!?!??
