Ixpand 32gb _ IOS Yosemite OS X
Unable to load application sofware on MacBook Air; continually get error message; anyone else with this issue, I’m running “Yosemite OS X”
There is no software for Mac or any computer for that matter. The only app available is for iOS devices. The iXpand just functions like a normal USB drive with the computer. What software are you trying to install?
trying to down load this, Sandisk says the Ixapnd is plug and play…not with mine
Download SecureAccess(version 3 for iXpand only) :
- Download for Mac (12MB for iXpand only)
ah your talking about the encryption software. You do not need that to use the drive. That is only used to unlock files on a computer if you choose to lock them from the iOS device.
If you want to use it you actually install and run it on the iXpand drive not the Mac HDD. in the install screen (make sure the iXpand drive is connected) just select the iXpand as the install location.
Transferring files between a MacBook or laptop and the iPhone is always a bit of a hassle. You have to turn Bluetooth /airdrop on, or you have to email the file to yourself, which is a bit of a problem if you don’t have access to wifi. This pen drive makes such transfers very easy. It was easy to setup and share files between MacOS, iOS as well as Windows. You can share any files, not just pics.
Of course the added bonus is that you can free up space on your iPhone (if needed) by transferring or copying files to this drive. And if you are in a hurry, you can download your work directory to this drive and work on it plugged to your iPhone. This model connects with USB and lightening connector phone. The quirky curve is actually designed to allow you to use the iPhone while this is plugged in. get-shareit.com get-vidmateapk.com
The SanDisk iXpand is unquestionably the best thumb drive for the iPhone X and iPhone 8. The device is available in four different capacities: 32GB, 64GB, 128GB, and 256GB. It can transfer data to your phone at 13MBps and supports USB 3.0 when connected to a computer
