I needed to find a movie/video player for someone who doesn’t have an MPW, and wanted to copy some old movies to his iPad for playing later. I found some information about Player Xtreme so decided to give it a try.
It seemed so good I have installed it myself, on an iPhone 4, and older iPad, and an iPad Air. Its main claim to fame is that it will play almost any video format, without conversion. Not DRM as far as I know, but I don’t have any of them to test with.
I specifically needed it to play FLV and MKV files, which it does fine. I also needed to be sure it played AC-3 and DTS 5.1 audio, and it does. I know playing MKV and AC-3 have been an issue for some MPW users.
The Pro version also adds DLNA renderer functionality, and can connect to network shares.
Better still, after I had played around with the free version for a while, transfering a couple of movies to a my iPhone 4 and playing bits of them, I got a pop-up message saying that “for a limited time” if I wrote a review I would get a free upgrade to the Pro version. So I hit the button to go to the iTune App store, looked at the existing reviews for a couple of minutes, closed the App store, and went back to Player Xtreme, only to receive a message, “Did you write a review?” I said “Yes” of course, and received a free upgrade to the Pro version. Sweet!
So if you are looking for another player, wich looks to be pretty good, and you want connection to network shares and DLNA servers, download Player Xtreme now and “trick” them into giving you the full version for free!
Note 1: I have absolutely no affiliation with the developer or software.
Note 2: I will probably write a review after I have actually tested it for a while, rather than minutes after installing it.
Note 3: It still didn’t play high bit rate movies well on my old iPhone 4, as the iPhone just doesn’t have the power to play those files. It does play lower bitrate FLV files very well though, for example.
