The USB connector is inherently faulty on ALL MY BOOKS due to the cheap and nasty way it is manufactured. I was horrified to find this out after buying my 2TB My Book 3.0
This is NOT a slamming post at WD - just bringing this to the fore as I think it is disgraceful that Western Digital have not implemented a design fix years ago.
100’s of thousands of peoples Data is at risk - cos many of the MY BOOKS versions SECRETLY “hardware encrypt” your data whether you ask it to or not!
If the weak USB connector breaks at the solder joint you are all screwed!
Just to add - I have loads of WD hard drives that have given me 10’s thousands of hrs reliable service - praise indeed!
Here is a post from the internet
My Book 3.0 Connector Failure ,
March 6, 2011
By James R Young
I purchased a 1TB my book 3.0 and used it for about a month and a half until the connector pulled off the PCB. This seems to be a recurring problem with these drives. Fortunately I backed it up the night before this happened but I did add more files the next day. I decided that getting the content off the drive was more important than dealing with the warranty so I took it apart to re-install the connector. I am an electrical engineer with access to a microscope and experience re-working fine pitched electronic assemblies so temporarily fixing the connector isn’t much of a reach. I am also experienced in inspecting electronic assemblies for causes of failure.
I found that the connector came off due to cold solder joints. The connector is soldered to the PCB and several locations to provide support. Unfortunately the pads are connected to the ground plane and there isn’t sufficient thermal relief requiring a significant amount of heat to make a good solder joint.
The solder joints on my drive were never heated enough so they broke with very little force applied. The poor soldering in combination with the stiff cable provided were the cause of the failure. The poor quality of workmanship makes it inevitable that many other users will have the same problem.
Thank you for addressing this problem which I hope will be escalated to the attention of top management in order to keep the reputation of Western Digital intact!
Thousands of folks back-up data is being lost due to this unfixed, not fit for purpose, USB socket manufacturing design fault! which is NOT fair! ![]()
