Kinda new to this backup stuff. I have a Passport ultra and was wondering. If you do a regular backup eg. pictures, music, docs and then you want to also back up a couple of other files with the file backup. When you disconnect and reconnect later will it do an incremental backup on all the pictures, music, and docs as well as the files that you chose or is it kind of a “One or the other” type thing? Thanks in advance. CC
Hi CChamp, Smartware will continue with the last backup configuration it had, so if you selected file backup it will stay using that backup setup until you change it again.
