hi
when I store data mixed with pictures and movies , the pictures transformed to my passport but the movies not all of them why ?!
I have tried to download the software that formats the "my passport "
but the same problem it gives me an io error .
That happens just when I try to move a movie or video clip to my storage .
and that’s not all ,
when I tries to eject the USB it is stuck and I can’t get it out.
i have try full format and error check but it got stuck i mean it didn’t continue with the process i chose it to do
Thanks for the helpers.
i have tried the new
Data Lifeguard Diagnostic for Windows
and this is what i got :
Test Option:
QUICK TEST
Model Number:
WD 3200BMV External
Unit Serial Number:
WXE409CU8081
Firmware Number:
1.75
Capacity:
320.07 GB
SMART Status:
FAIL
Test Result:
FAIL
Test Error Code:
11-Cable Test::Read diagnostics sector error!
Test Time:
10:15:05, April 21, 2010
Test Option:
WRITE ZEROS
Model Number:
WD 3200BMV External
Unit Serial Number:
WXE409CU8081
Firmware Number:
1.75
Capacity:
320.07 GB
SMART Status:
FAIL
Test Result:
FAIL
Test Error Code:
Test Time:
10:16:17, April 21, 2010
Test Option:
EXTENDED TEST
Model Number:
WD 3200BMV External
Unit Serial Number:
WXE409CU8081
Firmware Number:
1.75
Capacity:
320.07 GB
SMART Status:
FAIL
Test Result:
FAIL
Test Error Code:
Test Time:
10:16:28, April 21, 2010
Test Option:
QUICK TEST
Model Number:
WD 3200BMV External
Unit Serial Number:
WXE409CU8081
Firmware Number:
1.75
Capacity:
320.07 GB
SMART Status:
FAIL
Test Result:
FAIL
Test Error Code:
Test Time:
10:17:57, April 21, 2010
Test Option:
EXTENDED TEST
Model Number:
WD 3200BMV External
Unit Serial Number:
WXE409CU8081
Firmware Number:
1.75
Capacity:
320.07 GB
SMART Status:
FAIL
Test Result:
FAIL
Test Error Code:
Test Time:
10:18:05, April 21, 2010
Test Option:
WRITE ZEROS
Model Number:
WD 3200BMV External
Unit Serial Number:
WXE409CU8081
Firmware Number:
1.75
Capacity:
320.07 GB
SMART Status:
FAIL
Test Result:
FAIL
Test Error Code:
Test Time:
10:19:07, April 21, 2010
and idea will be helpfull
thanks for the helpers
bill_s
April 21, 2010, 6:46pm
3
I will have someone look at this to verify that it is indeed your drive and not the utility.
LB_WD
April 21, 2010, 9:03pm
4
What version of Data Lifeguard are you using? Did you download the new 1.21 version? If not, I would recommend that you download the latest version and try to run the test again. If you are still having problems I would try the drive in a different computer and change the USB cable. If the issue continues, then you may need to replace the drive. Please see the link below to download the latest version of the software.
Data Lifeguard Diagnostics v1.21
http://support.wdc.com/product/download.asp?groupid=612&sid=3&lang=en
thanks
i have tried the last version u gave me , and here is the result :
Test Option:
QUICK TEST
Model Number:
WD 3200BMV External
Unit Serial Number:
WXE409CU8081
Firmware Number:
1.75
Capacity:
320.07 GB
SMART Status:
FAIL
Test Result:
FAIL
Test Error Code:
Test Time:
09:31:42, April 22, 2010
Test Option:
EXTENDED TEST
Model Number:
WD 3200BMV External
Unit Serial Number:
WXE409CU8081
Firmware Number:
1.75
Capacity:
320.07 GB
SMART Status:
FAIL
Test Result:
FAIL
Test Error Code:
Test Time:
09:31:50, April 22, 2010
Test Option:
WRITE ZEROS
Model Number:
WD 3200BMV External
Unit Serial Number:
WXE409CU8081
Firmware Number:
1.75
Capacity:
320.07 GB
SMART Status:
FAIL
Test Result:
FAIL
Test Error Code:
Test Time:
09:32:04, April 22, 2010
i will try it on other computer ,
and how do i raze the number of ur star i mean how do i " kudo " u .
bill_s
April 22, 2010, 9:02pm
6
Just click on the star next to the number.
