I bought a new SanDisk cruzer blade flash drive and I try to connect it with Android but it's showing nothing in file manager how do I connect it and transfer data
Plz solve it plz plz fast
Hi @Lxsh0001,
Have you tried connecting it with another cable? Also, connect it to a Windows PC and open Disk Management (right-click on the Start button and select ‘Disk Management’ from the menu) to check how the flash drive is showing up.
If your flash drive is missing a letter, right-click and assign a new drive letter, such as F:.
You can also try other methods, such as using the Windows built-in disk repair tool to fix the issue, updating / reinstalling the USB drivers, reformatting the flash drive. ( Read further: How to Fix USB Flash Drives not Showing up in Windows )
