I accidently formatted my drive!
i accidently formatted my drive !!! and now i cant find my smartware can ayone here plz help i have got 500gb my passport essentials portable drive
http://wdc.custhelp.com/app/answers/detail/a_id/5419/session/L2F2LzMvdGltZS8
xMzI5NjYyMTUzL3NpZC9HajJjNzVSaw%3D%3D
i actually i found out the software for the hadrive but when i install it it says not started frm drive can anyone plz help me with that
Uninstall Smartware if you previously had installed.
Update the firmware , update SES drivers and then run the Smartware application from the drive
okay leme see that if it works
Dude, if you formated it then your done, the data is overwritten. The only way to get back the data is with specialized software. This is because a format does not per say delete the data, it just labels it as empty and then allows a new partition to write over it. So dig around for some recovery software, thats all you can do.
nah its all rite i alreday had the back up what i want was hds orginal software u knw smartware]
Oh good, hey if anyone here can give my problem a shoot I would be EXTREAMLY greatfull.  http://community.wdc.com/t5/My-Passport-for-PC/Drive-starts-to-Write-Then-stops-indefinably/td-p/357167
where do i get the software frm man evrytime i try it running frm the website i all i get is this dammed msg saying not started frm drive
You can try donwloading the latest version of WD SmartWare from here.
i already did that but still it says not stared frm drive
