I have bought 8 HUH721212AL5200 12TB SAS drives, and 3 where giving off SMART errors so bad, the Dell PERC controller flat out refused to use them, they where RMA’d and replaced after inspection.
The 3 new drives have now been installed, and one is immediately starting out with the same errors, and another of the not RMA’ed disks, is now starting to report the same errors.
Is anyone familiar with these drives, I am hard pressed to believe what I am experiencing here.
From the original SMART output…
=== START OF INFORMATION SECTION ===
Vendor: HGST
Product: HUH721212AL5200
Revision: A925
Compliance: SPC-4
User Capacity: 12.000.138.625.024 bytes [12,0 TB]
Logical block size: 512 bytes
Physical block size: 4096 bytes
LU is fully provisioned
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Logical Unit id: 0x5000cca291483e00
Serial number: *********
Device type: disk
Transport protocol: SAS (SPL-3)
Local Time is: Tue Oct 13 00:25:37 2020 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Temperature Warning: Enabled
=== START OF READ SMART DATA SECTION ===
SMART Health Status: FIRMWARE IMPENDING FAILURE SEEK ERROR RATE TOO HIGH [asc=5d, ascq=63]
Current Drive Temperature: 32 C
Drive Trip Temperature: 85 C
Manufactured in week 17 of year 2020
Specified cycle count over device lifetime: 50000
Accumulated start-stop cycles: 19
Specified load-unload count over device lifetime: 600000
Accumulated load-unload cycles: 29
Elements in grown defect list: 0
And errors after running test…
Error counter log:
           Errors Corrected by           Total   Correction     Gigabytes    Total
               ECC          rereads/    errors   algorithm      processed    uncorrected
           fast | delayed   rewrites  corrected  invocations   [10^9 bytes]  errors
read:          0        0         0         0       2965       1109,600           0
write:         0        0         0         0         33          0,023           0
verify:        0        0         0         0        621          0,003           0
Non-medium error count:        0
SMART Self-test log
Num  Test              Status                 segment  LifeTime  LBA_first_err [SK ASC ASQ]
     Description                              number   (hours)
 # 1  Background short  Failed in segment -->       3      17                 - [-   -    -]
 # 2  Background short  Failed in segment -->       3      17                 - [-   -    -]
 # 3  Background short  Failed in segment -->       3      17                 - [-   -    -]
Edit: removed markdown formatting, and made it more code-like instead.
Edit2: removed disk serial number.
