I have the 3TB, USB 3.0 Essential working on my HP Laptop with Vista. I’d like to move all the files off my old desktop with XP.
When I downloaded the SmartWare and ran back-up, it appears that the files from my HP were copied onto my desktop not the other way around. Can’t seem to figure this out, but here is my goal:
- WD MyBook Essential is the single back-up drive for two computers
- all files from the desktop move to the MyBook, so I can trash the old PC
I’m a novice, so any technical advice in plain language would be most welcomed.
If you would like to backup the files from the XP computer, you can do it manually by using copy/paste or using Smartware. If you used Smartware on the XP computer, follow the link below for the steps to retrieve the backup.
How to retrieve a backup using WD SmartWare Version 1.6.x and earlier
http://wdc.custhelp.com/app/answers/detail/a_id/3829
How to move or copy files from one hard drive to another in Windows
http://wdc.custhelp.com/app/answers/detail/a_id/1198
Thank you very much. I really appreciate your technical expertise
