How to split safely "My Book Duo" in 2 drives
When I began using my “My Book Duo”, I’ve organized it as a single drive.
Actually I see that it wasn’t good idea.
Is it possible to split the “My Book Duo” in 2 drives if it actually contains data.
Thanks in advance.
Pavel.
Hi there,
If its a My Book Duo, you should be able to set the unit in JBOD, however if you already have information you wont be able to do this. If you do not have information , then just do it using the WD drive manager software.
