I can find no way to run smart self test on this usb 3.0 external drive.
How is it possible?
Currently testing with DLG as it seems to be the only way to run a smart self test…
When I try to run smart test with Hard Disk Sentinel I get the message:
“The hard disk controller or its driver do not support this function.”
It seems the problem is only with external usb hard drives and ssds.
WD Elements Desktop supports only Windows Data lifeguard Diagnostic tool to diagnose or run tests to check the health of the drive. You can refer below article to check the tool or software supported by WD Elements Desktop external drive:
