How to set up auto back up with WD Elements Hard Drive?
Hi. I have had to purchase a new laptop with Windows 10 as my old one crashed. I now have a WD Elements Hard drive back up and need to know to set it to do auto back up from my files please. Can’t find any information. Thanks.
Hi @wendy1 - Your post was in the “Forum Feedback” board - I moved it to the appropriate section of the Community.
Regarding your issue: The WD Elements is a bare-basic drive that does not come with any backup software. You can use Windows File History to do a backup using the tools built into the OS, or you can optionally purchase and use a third party application.
The article below is for Windows 8, but the steps should be similar in Windows 10.
https://support.wdc.com/knowledgebase/answer.aspx?ID=9591
thanks for your help Scott. Have turned on File History and will check that it works ok.
