i need solution for remove duplicate photos from pendrive and hard disk…???
Please help me out this problem
Looking and remove duplicate photos and similar photos without doubt using you can try VIVANTOOL Duplicate photo remover software. you can easily preview all duplicate photo files and also similar photos in your desktop/laptop. best utility help you fix your problem within second without any problem easy to use application.
Duplicate Photo Remover Tool to Find Duplicate Images JPG, JPEG, GIF, PNG
Although its a Old Thread But replying bcz may be someone at present can have this kind of problem. I used Duplicate Files Fixer for windows and still using. Every month i run a quick check to check my duplicate files so remove unecessary storage.
My recommendation: Try Czkawka if you use Windows. Scan your pendrive and hard disk separately, review the duplicate results, and delete only the copies you no longer need.
You can check them one by one delete them so you can delete any important image
