How to recover very old pictures in digital camera sdcard
I think MobiKin Doctor for Android is a good Android data recovery software. It helps us recover lost or deleted photos from  external SD card, such as contacts. However if you have already written over the sections of the SD card. Then there is really nothing you can do to recovery them
To recover old pics in digital camera SD card can be done utilizing Wondersahre Recoverit. This recovery software will help you regain your old as well as new deleted pics and videos within a few minutes. In case you need a tutorial then check this Youtube video https://www.youtube.com/watch?v=W72j-h4uFcA and you will be able to learn it in detail. It has a dynamic algorithm that has amazing accuracy. There is no need to be worried about the time span as this software is simple to utilize and does wonders within minutes.
Have accidentally deleted or removed your camera photos off from inner used SD card for accidental deletion, format or other reasons? Have you checked this memory card with any photo recovery software? How many original photos have you retrieved?
If you still have something wanted to restore, you can try my ways: simply adding nothing new on this memory card and use stillbon photo recovery software that can always do its utmost to get all possible stuffs back.
I hope you can retrieve everything back with luck.
Check more detailed information here:-  https://www.stillbonsoftware.com/photo-recovery/
If you are looking for a Photo recovery tool then I think apart from the above listing tools, you should also check once Stillbon Photo Recovery Tool. This tool has the capability to get back lost or deleted photos or videos from any digital devices like SD card, memory card, memory sticks, external hard drive, and other devices.
You can know more about this tool at:- https://www.stillbonsoftware.com/photo-recovery/
Based on your description, it seems you deleted the photos four months ago and have since taken new ones with the camera. Is that correct?
If standard recovery software can only find recent photos, the main reason is that the space occupied by the older photos has been overwritten by new data. As long as that data has not been completely overwritten, deep recovery is still possible.
Please remove the SD card from the camera immediately. Do not use this card to take photos or save new files, as this prevents the old photo sectors from being overwritten again.
When running recovery tools on your computer, ensure the software is installed on your computer’s hard drive—never on the SD card itself. Try using a more powerful scanning tool to perform a deep scan, and save any recoverable files directly to your computer instead of the SD card.
Read also - How to Recover Deleted Files from SD Card on Windows & Mac?
