I copied the file to a USB flash drive and the light was turned off. I turn on the computer, there is write protection on the flash drive. Formatting is not possible. Give me some advice
@amr
(Get Support for Your SSDs and Flash Products | SanDisk)
Try this one.
(Contact Support | SanDisk)
If your USB drive has write protection and can’t be formatted, try the following:
- Check for a physical switch on the drive that might enable write protection.
- Use Diskpart in Command Prompt to clear the readonly attribute:
- Type
diskpart,list disk,select disk X, andattributes disk clear readonly.
- Use the Registry Editor to set
WriteProtectto0underHKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies. - Run CHKDSK to check for errors with
chkdsk X: /f.
If these steps don’t help, the USB drive might be failing.
