This is what I want to do, the question is how can this be done using the Smartware software.
I have purchased two 4 TB Smartbook Drives to back up my photographs and the intention is to leave one unit at an off-site location and the second unit connected to my home PC. Once a month I would then bring the off-site unit home and take the one from home to the off-site location. I would then connect the off-site unit to my home PC and the intent would be that it would add whatever files I created in the past month and continue backing up files for the next month. Then repeat the process. Backup process is set to continuous.
I have already populated one of the 4 TB MYBook drives with the data, have disconnected it and now connected the second unit but it is not making any back-up copies to the second drive.
What do I need to do with the software or the second drive to make this work?
Thanks
