Somehow Acronis Backup divided my external usb Ultra into two Disks. Win7 Disk Management shows
Disk 1 Removable (E:) No Media
Disk 2 931.36 GB Online
[quote=“LGalina, post:1, topic:156481”]
Disk 1 Removable (E:) No MediaDisk 2 931.36 GB Online
[/quote]Sorry, hit Enter too soon. ;(
Disk 1 Removable (E:) No Media |
Disk 2 931.36 GB Online | 931.36 Unallocated
Trying to get the Ultra back to original configuration. Windows Explorer no longer even recognizes the Ultra. It does eject the Ultra but when reconnected, it says “Please insert a disk into Removable Disk (E:)”. I guess I’ve really messed it up. Thanks for any help. I know you are busy.
I believe you will have to delete both partitions and then format the drive again.
Thanks Hamlet.
Unfortunately, I could not find a way to use Win7 Disk Management function to do that as the delete function was inactive.
However, I used WD Drive Utilities tool to erase the drive. Win7 Disk Management now recognizes it as Disk 1 931.48 GB Healthy (Primary Partition). I don’t know what all that means but I was able to use the drive to store an image of C:\ drive. ![]()
