How do you organize large video collections on portable storage devices?
Hi everyone,
I’m looking for practical tips on organizing large video collections on portable storage devices.
How do you usually manage folders, file names, duplicate videos, and backups when storing a large number of video files on a USB drive or portable SSD?
Are there any recommended file-management practices that help keep collections organized and make files easier to find?
I’d appreciate suggestions from people who regularly work with large media libraries.
Thanks!
@jennystudenroth
Here’s my layout for the past 20+ years, but I never fill any drive past 50% capacity which can vary year over year.
  • Drive 1: 2023 / Event Name
  • Drive 1: 2024 / Event Name
  • Drive 1: 2025 / Event Name
  • Drive 2: 2025 / Event Name
  • Drive 1: 2026 / Event Name
  • Drive 2: 2026 / Event Name
I do not micro manage backups. I let the backup software do it’s thing and never manually touch a single file on the backup drive. Always use software to restore. I’m using Windows File Backup to a dedicated backup drive and then important into my NAS for redendency.
So 3-2-1 backup policy:
  1. No saved files on the local computer
  2. COPY #1: Useable files on many different drives based on year.
  3. COPY #2: Backup to a different drive. (I only use 2 TB SSDs. If one fails, I only loose 1TB of data since I do not fill past 50%)
  4. COPY #3: Backup my SSD to my NAS. (RAID 1 Mirror)
Hope this helps
I usually recommend keeping a simple folder structure based on year, project, or category. Use descriptive file names with dates so videos are easier to find later.
Also, periodically check for duplicate files to save storage space and, most importantly, keep a backup on a separate drive. Never rely on a single USB drive or portable SSD for important videos.
A little organization and regular backups can save you a lot of trouble in the long run.
One thing that helps me is keeping a small index file with the drive name and a few details about what’s stored on it. When you have several portable drives, it’s easy to forget where a particular video is.
I also try to avoid changing folder names too often, especially after backing everything up. Keeping things consistent makes searching and restoring much less of a headache.
