Once logged in, you’ll typically need to input information about the HGST drive you wish to register. This may include the drive’s serial number, model number, purchase date, and place of purchase. You can find this information on the drive’s label.
I recently bought two HGST 10TB drives, which are working fine with no errors shown in Crystal Disk Info. However, when I try to register these drives Patient Gateway on the WD Support site, I get an error message: “Please correct the following error(s): No results found.” I uploaded both the Amazon order PDF and a scanned FedEx receipt from the seller as proof of purchase.
Hi there! Glad to hear your HGST 10TB drives are working well. The issue with WD registration might be a glitch; double-check your files and try a different browser. Also, if you’re into unique projects, have you ever explored mushroom spores? They’re fascinating for research or even cultivating mushrooms!
