Im sick of this bugging software that resets the caching allmost everytime i restart the computer.
So how do i return this faulty hardware/software ?
Return it to where you bought it from?
Thought Sandisk would answer, but sence they didnt im returning it.
This ■■■■ should not have been released. It works for a couple of hours, then resets.
Epic fail sandisk.
Im returning mine tomorrow.
This is a user’s forum, so it is not surprising you did not get a response from the company. If you wish to speak directly to SanDisk and/or their Tech Support about this issue/product, I suggest you use the available contact avenues located here:
http://www.sandisk.com/about-sandisk/contact-us/
Btw, you only asked how to get a refund, which I answered with the obvious. Had your question been more serious or looking for assistance, so might have been the reply.
Please see the post SanDisk just posted: http://forums.sandisk.com/t5/SanDisk-ReadyCache-SSD/Any-way-to-stop-quot-cache-has-been-reset-quot-dialog-popping-up/td-p/299181
Interesting, so its an UI error not a real flush, just some data is emptied as the drive fills…
