Just wondering if there is any software (WD or otherwise) that will tell me what drives are inside my “My Books” I have 2 x 6TB and just wondering and don’t fancy jamming them open to find out.
In most cases clicking on a drive’s Properties will give you plenty of info about the drive.
No it gives Zero info about the drive itself, just comes with with the usual “My Book” or “Elements” or something on those lines, even banging in the drives SN will come back to my book as well
CrystalDiskInfo will give you the info.
example: this is my 3TB My Book
and then google search … WDC WD30EZRX-00DC0B0
Result: It’s a WD Green Drive.
Looking at dis-assembly youtube guides for the 6TB My Book … they are most likely WD Blue Drives and the 8TB My Book’s are probably Reds.
Many thanks Joey indeed it gave me the results i needed and both of mine are Blue, many thx for your help.
