How do I back up specific files and folders using WD My Passport Essential SE and WD SmartWare?
I don’t want to use the categories provided by WD. I want to select my own folders and files.
Any help will be apreciated.
Thanks
Thanks
I wouldn’t use the Smartware it’s junk. You might try this http://support.wdc.com/product/downloaddetail.asp?swid=119&wdc_lang=en
Joe
Thanks, but i don’t see any option to select the folders and files that I want to back up.
I can only select a full partition.
there are some paid softwares out there for it
here is an example from a freeware application Syncbak
http://www.2brightsparks.com/downloads.html
a folder named “nightly local backup”
where you can synchornise the source folder from your pc to the destination folder on your drive
