How do I back up data on my "My Passport Pro"?
After copying films/photos from an SD card to the MPP (My Passport Pro) I wish to then backup the MPP to a “My Passport Ultra”.
How do I do this?
The “My Passport Ultra” will only connect to the MPP via the USB port and the MPP wants to copy the data FROM the “My Passport Ultra” TO the MPP!
I need the copy to be from either/both the “SD Imports”/“USB Imports” on the MPP to the “My Passport Ultra”
I am struggling to understand how.
I can access the MPP via my iPad but this does not seem to help.
Any help will be much appreciated
Regards
Martin
Hi, you can back your My Passport Pro onto the My Passport Ultra using the WD Smartware and having both drives connected to the computer.
https://support.wdc.com/knowledgebase/answer.aspx?ID=16773
https://support.wdc.com/knowledgebase/answer.aspx?ID=3828
