I need to backup files from ‘My Passport Wireless Pro’ to second backup (External Hard Drive) for protect my files.
Do you suggest solutions for me ?
Thanks for your help ![]()
No mystery here, you just COPY folders/files from MPWP to your external drive. You do not want a “backup” you want exact copies. so that if you ever need to replace the folders and files on the MPWP they are ready and able to go on it from the drive with the copies – you just do the reverse of the first step.
Connect both drives to your PC.s USB ports and copy from one drive to the other drive.
Is there a way to copy the content of MPWP to a external HD with only the use of an Ipad or Iphone ?
