Hi gurus,
i am requesting help to identify if the burnt component is a TVS Diode as i accidentally over-voltage the external drive using a plug meant for laptop.
attached is the whole of PCB and close up part on the suspected burnt component visually read as “6BE XXX”
request help to identify as currently the drive stopped spinning with the USB bridge card displaying rapid white light.
USB bridge is working fine as i had successfully connected a SSD and can be read by a laptop.
thank you
