Western Digital My Book 2TB and My Passport Ultra 1TB
No more seen by windows 7 AFTER the last updates
I am enclosing the screenshot of ONLY the Passport Ultra 1TB
Where there’s the “F” Unit, I should have the “unlock.exe” file which is no more there
The same goes for the “My Book” HD
I need help, please !!!
Thank you
Roberto, Milano, Italia
**** UPDATE ****
Had to replace the image … This is the screenshot from “My Computer” at home
Look at the K Drive …
Are you able to test the drive on a different computer?
If the unit was working before the update, make sure that the drivers for the USB ports were updated as well.
Well … I got to tell you … After SEVERAL days the 2TB Unit was “unplugged”, now I can lunch the unlock.exe
But it says that I have to FORMAT the unit …
About “checking” the USB drivers, I would like to know how to do it.
I made a “clean” with CC CLEANER and DISABLED all the services as someone suggested me on the Windows Community.
So I would say a little step has been done.
Now the unit is there ( I am talking of the My book, the My Passport is still “out” ) but I would like to SEE and get back my files …
See this
Impossible to access to O:\
The volume doesn’t have a recognized file system.
Check that all the necessary drivers are are loaded for the file system and that the volume is not damaged …
Is it DEFINITELY dead ???
