[HELP] - My SSD Is Running Slow!
Hello friends,
I have a 240GB SanDisk SSD Plus, which was running very slow from yesterday night. I have been using this for 1 year, but this kind of problem I had never faced before. This problem starts after working on the computer for a while.
Not understanding what to do, I did some online researches and found this post where suggested to enable AHCI mode from the BIOS menu, I have not done it before. So my query is if I enable it, will I face any issues in the future? Kindly respond to this thread.
Hi @VeronaBotsford,
In order to check speed of your flash drive we recommend you to please use the below software to make a general assessment of your testing.
• To download the software, please refer to the below link:
Windows: CrystalDiskMark
Mac: BlackMagic utility
• Run the file and Install the software by following the installation wizard.
• Once the software is installed, please locate the “CrystalDiskMark Application” icon on the desktop
• Double click the icon and then select the SanDisk flash drive in the Device box.
• Run the speed check read & write speed.
• Once this process will complete, share screenshot of test results with us on support@sandisk.com
• Disclaimer Notice: Use of Third-Party Software or Websites - Disclaimer Notice: Use of Third-Party Software or Websites
