Mike_e
1
Hi everyone,
Im having issues with a “my passport essential” running on windows XP on my bosses computer
Problem is when I plug it in windows wont recognise it. As in I can safely remove it. but does not appear as a volume under my computer?
any help much appreciated.
Cheers,
Mike
bill_s
3
Since there’s been no replies, maybe you should try contacting WD’s Technical Support about this. You can do so either by phone or email.
http://support.wdc.com/contact/index.asp?lang=en
