I have WD 1 TB portable hard disk. When I connected this with my laptop, it opened up initially prompting me to scan for errors But then it froze. Upon restarting the same never appeared in My Computer but I can see the same in disk manager and device manager. I have tried every single method to get it work but failed. I do not want to loose this. Please let know if any way to save my hard disk.
Sure, it seems like your WD 1 TB portable hard disk is giving you some trouble. It’s great that you can still see it in the disk manager and device manager, so there’s hope. Let’s try a few things to get it back on track. First, we can try assigning it a new drive letter in the Disk Management settings. Sometimes, just giving it a little nudge can do the trick. If that doesn’t work, we can check if the drivers need updating or reinstalling by going to the Device Manager. If it’s still being stubborn, we might need to consider using some data recovery software like recuva or stellar data recovery software to try to retrieve your files. If you’re still having no luck, we can give the disk a check for errors through the disk management tools. However, if none of these work, reformatting might be the last resort, but just remember, this will wipe all your data. If you have any important files, it’s a good idea to seek professional data recovery services. Don’t worry, all the best!
Hi Amelia,
Thanks for the revert. I have tried all the steps and it is still not working. When try to update the drivers, it says it has updated drivers. Also, There is no option to format. Tried using Recuva also but this is giving error as it cannot read the drive. Stellar reads the files but asking huge amount to recover the files.
I am ok to reformat but no success with even that as well. I have uploaded more screenshots which might be helpful.
Thanks for all your help.
Regards
Harish Kumar
Hi Harish,
I understand your concerns, and I’m sorry to hear that the suggested solutions haven’t been effective in resolving the issue with your WD 1 TB portable hard disk. It’s unfortunate that the data recovery software hasn’t been successful and that the cost for using Stellar is prohibitive.
Considering the situation, it might be worthwhile to seek the assistance of a professional data recovery service as they have the necessary expertise and tools to handle complex data retrieval cases. Although the cost might be high, it could be the most reliable option for recovering your important files.
If you’re considering reformatting the drive, please proceed with caution as this will result in the loss of all data on the disk. You should be able to initiate the reformatting process through the Disk Management tool, but it’s crucial to ensure that you have a backup of any critical files before proceeding.
I hope this information helps, and I sincerely hope you can find a suitable solution for your hard disk issue. If you have any more questions or need further assistance, please don’t hesitate to ask.
Best regards,
Amelia
I also have the same issue. I’m not able to “Initialize the disk”, Format or anything else.
My model number: WDBCKA0100HBK-NE32, SKU:6290669. Are there any recover services that western digital works with? Can western digital do the recovery process?
WD has its own diagnostic tools, such as WD Data Lifeguard Diagnostic, which can help you check the health of the disk and attempt repairs. First of all you need to format the disk in drive artinya https://www.handyrecovery.com/you-need-to-format-the-disk-in-drive-fix/. Hope i helps
Hope you’ve been able to sort this out by now. If it’s still an issue, and you’re seeing the you need to format the disk in drive error , there’s a good chance that the disk may need to be formatted to resolve the problem. I found this helpful guide: https://www.cleverfiles.cоm/howto/fix-you-need-to-format-disk-in-drive-error.html, which provides step-by-step instructions on how to fix this specific error. The guide goes into detail about what causes the error and how to safely format the drive without losing important data. Hopefully, it will help if you’re still facing the issue! Let me know if it works or if you need further assistance
Hi.
No, the tool of WD is no more operational and hence could not fix it. Thanks for the follow up though.
This kind of problem typically arises when the drive’s file system or partition table becomes corrupted. That can happen for a number of reasons: maybe the drive was removed without being safely ejected, the power was unexpectedly cut off during a transfer, or the computer froze while the drive was in use. Any of these scenarios can leave your disk in an inconsistent state that Windows can’t read. So instead, it prompts you to initialize the disk—essentially asking to rebuild the partition table from scratch. Check out the article to learn more soluitons about the “disk 1/0 unknown not initialized” error.
