I wan to remove SecureAccess, and all traces of it, and any other pre-installed software which comes with a new drive and about which we are told nothing.
I had already stored a few things which I wanted to be portable, but have temporarily removed them prior to flushing out everything else.
How, exactly, do I go about removing everything on the drive and starting afresh?
Formatting it would do it in one fell swoop.
Formatting is not possible on this bloody thing because you get the message ‘disk is write protected’ and there is no way you can remove the protection! I cannot even delete my files!
Have fun, have a lot of time and good luck!
I will never buy this bloody SanDisk thing again!
I bought two ‘16Gb’ Chinese made units. One of them shows 64kb instead of ~16Gb and does not work.
The drive which I wanted to format was also made in China. I had no trouble doing so at all.
When you buy goods you expect them to be in order, functional, I must have been unlucky to get both of the two items faulty. Even attempt to do low level DOS format did not work.
