gapless ?
Hello there, after lurking on some forum in order to found the right replacement to my now dead discman, i’ve been told that the sansa fuze read flac AND is gapless.so i bought it,but only to discover that it is NOT gapless,or so it seems.does anyone has a solution ? is there something i have to do that i haven’t discovered yet ?
If you had been lurking here , you would’ve discovered this is the most ‘entusiastically’ discussed topic on all the player’s boards here.
As far a a solution? The only one right now is to return your Fuze and buy a player that supports gapless. Is it in the Fuze’s future? It’s a case of
A definite maybe!
