G-RAID with Apple M5 Max
Dear all,
Any G-RAID 8-bay storage only works under Full Security on macOS 26 Tahoe (M5 Max chip)—it completely freezes under Reduced Security. Is there a known fix for this?
Thanks
It looks like a compatibility issue between the G-RAID 8-bay enclosure or its RAID driver and macOS Tahoe.
Does the Mac freeze as soon as you connect the G-RAID, or only when the RAID software loads or you access the volume?
