Hi. I have a correctly configured RAID0 drive. Disappearing has been an ongoing problem. If the drive appears and I don’t reboot or disconnect it, it is fine. Once I reboot, it is usually gone again.
This time, I just reversed the cable and it started working. Win10 updates required a reboot and now it’s gone again. So I spent $30 on a good TB4 cable but it is not coming back.
Windows does not see the drive. If I restart the drive or reconnect it, the drives are spinning. It will probably return within the next week as it often does.
I am on an Asrock X570 MB that has a dedicated TB3 card AIC 2.0. That is the connection to the Sandisk drive.
