I have a G-DRIVE Mobile SSD (1TB) attached to my Apple MacBook Pro (OS 10.15.7) with the supplied USB-C cable. If I have to restart my computer for some reason, the drive does not remount - i.e., it does not show up on the desktop. I have to detach the drive and re-attach it for the drive to show up on my desktop.
Hi @ldamario,
Please be informed that we usually recommend safely ejecting the drive from the computer when there are no activities performed on the drive and plugin back the drive back to the computer when need to work on the drive. However, you may contact apple in order to fix this issue, as it’s related to mac mounting after reboot and there are some settings that can be changed in mac to make it work with the drive.
