I recently bought a new MicroSDXC card from Best Buy. It has 128 GB of storage, so the computer managment program cannot format it. In addition, I have used other online utilites which have also been unable to format it. What should I do since the device I intend to use it with cannot format it either and also requires a FAT32 format?
I believe when I needed to re- re-format my 64GB flash drive (also SDXC) to FAT32, I used the HP Flash Drive Format Tool.
I seem to be having another problem now, the computer is not recognizing the SD card at all. Is this an issue involved with the SD card, and if so, how do I fix this?
