how can i get into my passport .WITHOUT loosing my data…forgot pass word and my old computor crashed…,took my password saver with it…i have 10 years worth of info i do NOT Wnt to loose you can email me at [Deleted]
any help isgreatly appreciated
if you can’t remember the password you are out of luck. There is no reset or work around and the data is also hardware encrypted.
Joe
Hi wcy1943, unfortunately it is not possible to unlock the Passport without the correct password, try using several combinations of known passwords in upper and lower case letters.
Unlocking a Drive
