I’m looking for 128GB USB 3 flash drives with Type A connectors and LED status lights.
What current models are available?
My system has relatively big buffers and says it’s done with transfers, etc. before it really is.
I can’t tell from the product descriptions which models have LEDs.
I don’t need the fastest drives. This is for backups, not regular use.
Hi @josephj
This doesn’t seem to warrant a support issue. The only support would be for SD to add indicator as a standard spec on their product listings.
I went ahead and bought flash drives that do not have indicators on them.
From observing the ones I have that do have indicators, if I wait around 10 seconds after selecting safely remove for the drive, I should be fine. It usually finishes well before that.
