Hi
I need help! I have a WD 2TB external WDBAAF0020HBK that I got for Xmas last year. I connected it to
my PC in March and MOVED all my music, books, pics etc from the pc’s internal HD to the WDBAAF0020HBK.
- I created the directories Books, DVDs and Music and MOVED my files into the appropriate directories.
2.The Music directory was just under 500GB, so I created the directories Music J-R, Music S-Z and Soundtracks
and moved all the soundtracks in the Soundtrak directory, J thru R music into the Music J-R directory etc.
I then renamed the original Music directory to Music A-I.
I then removed the drive via Safely Remove Hardware and disconnected it from my computer.
Last week I reconnected the drive to move more files onto it. I reconnected before startup and started my pc.
When I went to the R: drive (WDBAAF0020HBK) everything looked normal.
I started to move more directories/files from the pc’s HD into the Music S-Z directory. All started out normal then the
directories started to dissapear. They moved over and showed, but, as the next directory was moved, the previous directory and all others vanished. I stoped the move and exited the drive and did a reboot. I then went back into the
, clicked on the Music S-Z directory and it the pc just hung there. After about a minute it came back with:
Disk is not formatted
The disk in drive R is not formatted.
Do you want to format now?
I hit no.
It shows 0kb for the directory size.
Now if I go in I can create a new directory. It will show for about a couple of seconds, then disapear. I tried to add the
directory again and it tells me the directory already exists.
WTF! I’m at a loss here. It shows the the directory is empty, yet it tells me they are there.
I rechecked all directories and the Soundtrack directory shows empty, yet they are there if I try to make a new one.
The rest are OK and readable. Can ANYONE help? I don’t want to lose anymore files or move more onto it an risk
losing them also. HELP!!!
BTW! Im on XP SP3, Core 2 Duo
