do you have icloud photo library turned on? If so the photos may not actually be stored on your phone and would have to be downloaded to copy to the iXpand. You can check settings or in the photos app if you see all photos instead of camera roll it means icloud photo library is turned on.
this seems to be a common problem, and i still haven’t found a fix for this at ALL online.
this is very disappointing.
i get stuck and now it doesn’t even function at all and just shows the “iXpand Drive is full operation could not be completed” screen. and the buttons freeze and i have to shut the entire app down and restart.
I had this this problem.
My Sandisk stopped copying from my IPad (even though it said the SanDisk still had 400mb of space still left on it.)
I had 5193 photos and some videos on it.
So I transfered these photos from the SanDisk to another computer…
And deleted them from the SanDisk to make space.
Now it works again perfectly
So the answer for me was: My SanDisk was full - so I cleared off some space on it.
Hi can you please explain how did you delete the photos from SanDisk to make space? I am also getting the message Drive Full and cannot copy any more photos. I tried deleting the folders from SanDisk when it was attached to Mack. Now no files or folders can be seen in it. Yet it keeps saying Drive is full!
Thank you for your mail.
When the iXpand drive is plugged into iPhone, no files or folders are visible because I have deleted them earlier. I had also emptied the Trash Can, when the drive was plugged into iMac and despite that now the drive is showing “23 GB used out of 64 GB”. Don’t know which are these invisible files and how to delete them from the drive.
Please help if possible.
Thank you once again.
You’re welcome I’m happy to help.
I think it might be because you deleted the folders using your IMac rather than deleting them inside the SanDisk App on your phone.
Have you got all the files 100% copied safe onto your IMac now?
If you have all files copied 100% safe onto your IMac
you could totally erase the SanDisk in “Disk Utility” and start again with it:
Pity I did not read this post before making the purchase ,struggled with Airdrop continually failing so figured this iXand item would do the trick. Similar issues copies a few and then fails ,start again copies a few more (sometimes less) and so the cycle continues.
7000 photos to copy ,what to do !?
